Oelheld Introduces Forging Lubricants
Oelheld recently announced a line of forging lubricants at Forge Fair 2019. The company is also a proud member of the Forging Industry Association. Here are some highlights of the new products:
AirForge OH 40009: Combines cleanliness with the added lubricity of graphite in our synthetic die lubricant
AirForge OH 40009 is a synthetic high performance die lubricant for steel, titanium and nickel-based alloys. The product contains some graphite to add lubricity for deeper draw parts. AirForge OH 40009 is cleaner to work with, than a true graphite lube. The maximum die temperature is 300°C and the maximum work piece temperature is 1200°C.
AirForge OH 40028: Semi-synthetic die lubricant guarantees unblemished surface finish on aluminum
AirForge OH 40028 is a semi-synthetic die lubricant for warm forging aluminum up to 650 °C. AirForge OH 40028 is formulated for excellent lubrication and release properties. The product promotes superior material flow and guarantees un-blemished surface finish.
AirForge 4028: transparent synthetic die lubricant for the optimum die and workpiece cleanliness
AirForge 4028 is a synthetic, graphite-free, high performance die lubricant for steel alloys with excellent lubricating properties. AirForge 4028 can be used at temperatures from 900 to 1200°C. The excellent lubrication properties ensure no residue in the die and clean gravures.
