Okuma Genos L3000-M One-Saddle Lathe Designed for Cutting Exotic Materials
Okuma's new Genos L3000-M one-saddle lathe is stronger, faster and ideal for cutting a wide range of exotic materials with ease. The integral spindle motor provides increased machining capacity and highly rigid guideways handle powerful cutting capabilities.
The Genos L3000-M has high speed milling and Y-axis options on specific models, allowing users to select the best specifications for a particular workpiece length and shape. Shop floor productivity is increased with a mounted NC tailstock that allows for easy setup of various workpieces. TAS-C (Thermo Active Stabilizer) construction is standard and automatically compensates thermal effects to maintain tight tolerances.
The Genos L3000-M is an operator-friendly designed machine that simplifies cleaning, filtration and maintenance tasks. User-friendly features include a separate cooling tank for quick servicing, easy spindle access to reduce operator work burden and maintenance tasks, and reduced chip accumulation during long, continuous runs decreases machine downtime for cleaning.
