Ono Sokki Releases Digital Indicator
The EG-225 digital indicator is Ono Sokki's latest multi-purpose inch / metric switchable gage used for a variety of applications. It can be used as a bench top unit or for in-line measurement. The compact model conforms to AGD Group 2 mechanical specifications, which makes it directly interchangeable with existing mechanical gages, and the compact design ensures easy installation into most fixtures. The EG-225 performs highly accurate measurements to 0.00005" throughout its one inch measuring range, according to the company's press release. This indicator allows you to obtain simultaneously, maximum, minimum and range values with only one sweep or rotation of your part. The unit also has an adjustable measuring force, for taking accurate measurements on fragile and soft compressible materials that require low pressure.
A variety of measurement capabilities are provided to satisfy most applications, including preset, zero/absolute and a counting direction change switch. The EG-225 has a response speed that allows the spindle to travel 20" / sec. without an error reading. The indicator has a built in rechargeable battery for portable applications or may be used with the supplied AC-adapter. The EG-225 features a data output speed of approximately 40 data / sec. Other optional outputs include: RS-232C, USB Plug and Play, MTI, analog and to a wireless gauging system.
