OSG Highlights Cutting Tool Line at Eastec
OSG Tap and Die, North American Headquarters of OSG Corporation, is a manufacturer of taps, end mills, drills and thread-making tools. At the 2011 Eastec Exposition, OSG will be exhibiting an extensive line of high technology cutting tools, including the 3-flute coolant-through Mega Muscle carbide drill, the HY-PRO CARB 3-D and 5-D drills and the brand-new VGx and UVX end mill series. OSG's 3-flute coolant-through Mega Muscle drill is designed specifically for drilling at feed rates 1.5 to 2 times faster than a 2-flute drill. It may also be used at lower RPMs, which decreases the amount of wear and prolongs tool life. This design also leads to higher hole accuracy with less work hardening, which gives secondary operations such as tapping even more tool life. The brand-new HY-PRO CARB VGx Variable Geometry End Mill is an innovative milling tool with capabilities of chatter-free and stable consistent milling in mild to severe milling operations. Last but not least, the EXOCARB-Aero UVX End Mill is one of OSG's latest innovations on variable index and variable helix end mills, designed exclusively for exotic aircraft materials.
