PowerCool MaxLife Coolants Give Biostability and Performance
Rustlick PowerCool MaxLife and PowerCool MaxLife CF coolants are long-lasting water-soluble oils with new additives specifically formulated to give maximum biostability and performance for heavy-duty cutting and grinding applications, according to the company's press release. The advanced technology used to formulate PowerCool MaxLife coolants ensures the highest fluid performance, dramatically increases sump life, and decreases overall fluid use.
PowerCool MaxLife coolants are safe for all metals, including ferrous/non-ferrous metals, aluminum, brass, bronze, and copper. These products can be used for a wide range of low to heavy-duty applications including machining, cutting, grinding, milling. PowerCool MaxLife is available in two versions, chlorinated or chlorine free. Rustlick PowerCool MaxLife contains chlorinated EP additives and PowerCool MaxLife CF contains non-chlorinated EP additives and is also recommended for use on titanium. PowerCool MaxLife and PowerCool MaxLife CF are available in five or 55 Gallon containers.
