Ransohoff Introduces LeanJet RB-2 Part Cleaning System
The LeanJet RB-2 immersion cleaning system processes two (2) baskets of parts per cycle, up to twenty (20) baskets per hour. The RB-2 carriage can be easily modified to accommodate much larger parts. Designed to fit into your work cell area or a smaller production environment, the Lean-Jet RB-2 immersion cleaning systems clean using a patented washing and rinsing process of agitation, spray impingement, rotation, hydraulic purging through immersion, and heated blow-off drying. This "triple action" batch cleaning process was developed specifically to process a broad range of challenging parts, especially those with internal bores and passages. In addition, the RB-2 parts washer is designed to be equipped with ultrasonics if needed. Totally enclosed self-ventilating process - operator is not exposed to vapors or mists found in other cleaning processes.
As a standard design this cell washer processes parts in the industry standard Kadon style basket designed to hold and protect your delicate parts during the entire cleaning process. The carriage can be modified to accommodate your current baskets or new, custom fixtures. The RB-2 is a scalable platform that can be easily modified to accommodate much larger parts.
