Ransohoff LeanDrum CF Washer Offers Energy Efficient High-Volume Cold Forming Solution
Ransohoff, a division of Cleaning Technologies Group LLC, has introduced its LeanDrum CF Washer. This new platform provides an energy efficient, reliable solution for your high-volume cleaning needs, along with an innovated design for cold forming applications.
The LeanDrum CF features a very robust, lower cost option utilizing stainless steel tanks, drum and housing, premium electrical components, a full immersion cleaning system and forced air dryer technology to produce consistently high quality cleaning results over an extended machine life. With this new design, you may recognize less chemical utilization and have better oil control resulting in a longer bath life. In this new design, you will have the ability to apply more aggressive chemicals without foaming. The new LeanDrum CF is designed for easy access that will allow easy drum removal for maintenance, with no crane required.
The new LeanDrum CF is a wash, rinse and blow-off machine in a small footprint of 5.3ft. wide x 11ft. deep x 5.3ft. height. The part production rate is 12 CU FT/Hour at 2RPM design drum speed, with a variable speed drive capable of 1-3 RPM's. This machine offers full immersion cleaning, eliminating any need for pumps and nozzles. The new LeanDrum CF comes standard with 3-2-1 warranty.
