Reishauer Offers Wheel Mounting Cart
The Reishauer Wheel Mounting Cart, ErgoMount, enables the machine operator to ergonomically and safely change grinding wheels and clamping tool arbours up to a weight of 40 kg. The unit has been designed for the RZx60 gear grinding machine series. It allows the direct mounting of a grinding wheel on the main spindle without any additional tools. Thanks to the well-thought-out fast-changeover system and the relevant load-bearing elements, the changeover between the setups for grinding wheels and clamping arbours is done in next to no time. The electrical lifting axis is controlled by a joystick and makes for comfortable operation.
The mounting cart complies with all relevant machine and working guidelines; offers fast and safe changing of grinding wheels and workpiece clamping arbours; an integrated grinding wheel setup device, pivotable by 90°; fast-changeover system with ball lock pin; clear layout of operating elements and readout instruments; storage positions for two grinding wheel and 3 clamping arbours; includes a generously dimensioned and lockable tooling drawer; excellent maneuverability and compact design.
