Rex-Cut Introduces Cut-Off Wheels for Stainless Steel
The ALPHA-GREEN Stainless Steel Cut-Off Wheels Type 1 and Type 27 cut-off wheels feature a thin profile which cuts faster than conventional thicker wheels is available from Rex-Cut Products, Inc. of Fall River, MA.
Rex-Cut’s ALPHA-GREEN Stainless Steel Cut-Off Wheels are offered in Type 1 and Type 27 depressed-center styles in 4", 4-1/2", 5", 6", and 7" sizes.
Capable of cutting faster and cooler than conventional thicker wheels and producing a smaller exit burr, they feature a thin profile and proprietary-reinforced resinoid bonding system of aluminum oxide abrasives.
Suitable for cutting stainless steel pipe, rod, tubing, and sheet, Rex-Cut’s Alpha GreenStainless Steel Cut-Off Wheels are offered in two thin profile sizes: one 0.040" thick with 60 grit aluminum oxide abrasives and another 0.045" thick with 46 grit abrasives. Packaging is 25 or 50 per box.
