Sandvik Extends CoroMill 172 Range
The CoroMill 172 range will be extended as of October 1st. This disc cutting concept adapted for gears, splines and racks will now be available in module 3-10 (DP 8.467-2.540) with gear profiles in accordance with DIN 867 for gears and DIN 5480 for splines. CoroMill 172 disc cutters offer a versatile and time saving solution for milling of high-quality gear profiles. Thanks to the new indexable carbide insert technology and powerful iLock interface, the component can be machined in flexible, non-dedicated machines, such as multi-task machines and machining centers, as well as in hobbing machines. CoroMill 172 is designed to be able to hold a range of inserts, offering flexibility for customers producing gears and splines of close module size and similar tooth profiles. CoroMill 172 is an attractive alternative for milling of high-precision profiles in a wide range of applications. Diameters range from 2.480-10.000 in. (63 to 254 mm).
