Sandvik Extends Sialon Grade Range
Sandvik Coromant is extending its Sialon grade CC6060 range to support the turning and milling of heat resistant super alloys. These latest introductions include inserts for semi-finish to finish machining and are now available. Sialon grade CC6060 is optimized for productivity benefits in larger diameter components and longer lengths of cut. With notch wear resistance, this grade also provides the confidence to machine at higher depths of cut than other ceramic grades and is able to cope with higher feed rates and longer continuous cuts, according to the company's press release.
