Spectroline Introduces Industrial Leak Detection Kit
The Spectroline OLK-444 Industrial Leak Detection Kit is a kit that pinpoints leaks in any size oil-based fluid system. It locates leaks in hydraulic systems, compressors, engines, gearboxes and fuel systems, preventing expensive equipment breakdowns and potential environmental problems.
The kit features the OPTI-LUX 400 violet light LED leak detection flashlight. It has power comparable to a 150-watt lamp. The unit is compact, lightweight and rechargeable. Its violet light enables dyes to fluoresce more brilliantly and with greater contrast than with standard blue light inspection lamps.
Also included in the kit is a 16 oz (473 ml) twin-neck bottle of patented OIL-GLO 44 concentrated oil dye, which is compatible with all synthetic and petroleum-based fluids. When a leaking industrial system is scanned with the OPTI-LUX 400, the dye glows a bright yellow/green color to reveal the location of all leaks.
Rounding out the kit is an 8 oz (237 ml) spray bottle of GLO-AWAY dye cleaner, a charging cradle with AC and DC cord sets, dye treatment tags and fluorescence-enhancing glasses.
