Stafford Offers Mounting Collars with Multiple Bore Designs
Stafford recently introduced a universal mounting collar that can be supplied with different bore designs to fit rail mounts and other devices. The mounting collars have a flat surface with a countersunk and tapped hole that allows it to be mounted to a flat surface or onto a rail or shaft.  According to the company’s press release, the collars feature smooth-, hex-, square-, threaded-, or keyed-bores to eliminate the need for drilling holes or welding. The mounting collars are suitable for applications in machinery, power transmission, packaging, conveyors, laboratories and consumer products. The universal mounting collars are priced at $11.90 each.
