Starrett Introduces Range of AGD Digital Indicators
The L.S. Starrett Company has introduced a range of Digital Electronic Indicators conforming to true AGD (American Gage Design) Group 1 dimensions, providing the ability to replace traditional mechanical indicating applications in the smallest AGD size specification class. Starrett 2700 Electronic Indicators are the first digital gages to match true AGD Group 1 dimensions (1.70"/ 43mm diameter).
Starrett 2700 Indicators feature a 1.70" diameter, 270 degree rotating bezel, allowing different user viewing preferences. The gages are available in two displays: a single LCD Numeric IQ model (the largest of its class) with low battery warning and programmable ratios, or a Numeric/ Analog AD model showing the two displays simultaneously.
Gages feature a .400" (10 mm) travel, accuracy of ± .0001" (0.002 mm) on the F2715 models and accuracy of ± .0002" (0.004 mm) on the F2714 models. The gages can store and view 200 readings internally. Stored readings can be downloaded with included software and a USB style cable. Starrett 2700 Digital Indicators have a CR2032 cell long-life battery that can last up to 3,000 hours under typical use. Gages are output-compatible for SPC documentation via cable or wirelessly using a Starrett DataSure Data Collection device.
These indicators are Made in America, have a 3/8" (.375") stem with 4-48 thread and are available in four models based on display readout format and resolutions. Switchable resolutions are .001/ .0005/ .0001/ .00005 or .001/ .0005/ .0001 in inch. In metric readouts, switchable resolutions are 0.02/ 0.01/ 0.002/ 0.001 or 0.02/ 0.01/ 0.002 mm. Gage functions are easy-to-operate and include: Absolute True Position, Travel Reverse, TIR, Tolerance Settings, Floating Zero, In/ mm conversion, three Hold functions (max/ min/ freeze) and Auto Off.
