Manufacturing Processes Milling Product News Industry News
Sumitomo DFC Double-Side 90° Milling Cutter Offers High Wear Resistance, Precision and Efficiency
New from Sumitomo Electric Carbide Inc., the DFC Double-Sided 90º Milling Cutter is engineered for exceptional precision and efficiency.
The high toughness and special shape of the DFC six-edge insert ensure long-term, stable cutting and high efficiency machining with high feed rates. Cutting edges are optimized to provide excellent surface finishes.
Low cutting forces and high wear resistance of Sumitomo's DFC result in a long tool life. Machining accuracy is enhanced through the separation of the insert contact areas and cutting edges. In addition, a double-sided insert design reduces costs.
Recommended insert grades for steel include ACP200 and ACP300. For stainless steel applications, ACM200 insert grades are recommended and for cast iron applications, ACK200 and ACK300 insert grades are recommended.
The DFC is available in 1" to 8" in standard, fine pitch and extra-fine pitch styles for a variety of applications. Maximum depth of cut is 6mm.
For a limited time, Sumitomo is offering special savings on DFC Cutters, including BOGO, kit prices, free cutter with the purchase of inserts, and purchase of 30 inserts get 10 free. Offer ends March 31, 2016.
