Lubrication Lubricants Oil The Gear Industry Trade Shows & Events IMTS Features
Ten Myths About Gear Lubrication
Myth No. 1: Oil Is Oil. Using the wrong oil is a common cause of gear failure. Gears require lubricants blended specifically for the application. For example, slow-speed spur gears, high-speed helical gears, hypoid gears and worm gears all require different lubricants. Application parameters, such as operating speeds, transmitted loads, temperature extremes and contamination risks, must be considered when choosing an oil. Using the right oil can improve efficiency and extend gear life.
This article appeared in the May/June 1995 issue.
