Torque Transmission Introduces New Line of Right Angle Drives
Torque Transmission introduced a line of right angle gear drives designed for various motion control applications where right angle motion is needed.
Housed in strong, glass-reinforced nylon, the gear drives are available in two model groups. The RAB is a standard right angle drive and MAD is a miniature angle drives.
According to the company’s press release, the RAB measures 3-21/32" x 3-15/16" x 1-1/4" deep and weighs 12 oz. It employs shielded lubricant, hardened steel ball bearings and gears and is rated at 1,600 rpm, and 1/3 horsepower and maximum speed 3,000 rpm.
The MAD (miniature angle drive) model measures 1.25" x 1.25" and weighs 3 oz., making it suitable for applications where size and weight are a design issue. The MAD uses permanently lubricated gear drives, hardened steel helical gears and smooth-operating, non-metallic bearings and is rated at 1,800 maximum rpm and 1/8 horsepower continuous duty.
