Today, ZF provides more than 1.2 million transmissions per year to automakers like Aston Martin, Audi, BMW, Ford, General Motors, Jaguar, Land Rover, Porsche, and Volkswagen and employs more than 6,300 in its car driveline technology division. In 2001, ZF introduced the world’s first 6-speed stepped automatic transmission in the BMW 7-Series.
Dr. Harald Naunheimer, director of product development, car driveline technology at ZF, says that transmissions are highly individualized based on region and vehicle segment. “The models feature individual strengths, which, in turn, depend on the application conditions. Therefore, each case has to be individually assessed because general statements are not applicable.”
The type of transmission plays a key role in defining a vehicle’s character, image, segment and brand, making it a major factor in competitiveness. Each vehicle features individual strengths, depending on application conditions.
AMTs—Also known as sequential manual gearboxes (SMGs), AMTs have their roots in Formula 1 racing, using computer-controlled actuators that are prompted by paddle shifters mounted on the steering wheel. There is no clutch pedal. The system allows for both automatic and manual modes. SMGs are generally found on high-performance sports cars.
CVTs use a belt or chain to connect variable-diameter pulleys to provide an unlimited number of ratios. This allows for uninterrupted power to the wheels.
DCTs—Also called direct-shift gearboxes (DSGs), DCTs use two clutches instead of a single-sided clutch to transfer engine power through two sets of gears. The paths are set up similar to a manual transmission, with one path controlling gears 1, 3 and 5 and the other controlling 2, 4, and 6, but there is no clutch pedal. Also, there is constant power to the wheels.
Hybrids—With regard to hybrids, market share will depend on how the unit is used—mild or full-scale hybrid—and on regional legislation.
“North America and Japan are typically automatic transmission markets, with Japan using CVTs in the sub-compact market,” Naunheimer says. “Europeans still prefer manuals—but even that has dropped slightly.”
Since the introduction of the 6-speed automatic, several automakers have moved in this direction. At ZF’s automatic transmission plant in Saarbruecken, Germany, much of the production has shifted from 5-speed automatics to 6-speeds. Nearly all elements of the transmission are manufactured in-house. Based on application requirements, the plant can hone, shave, grind or match grind its gears.
