Vomat Offers Advanced Filtration System
The Vomat FA 480 – 960 series filtration systems process from 120 to 240 US-Gallons per minute and offer dimensions of 55 x 99 x 48 inches. Vomat systems require little floor space. The tank‘s oil volume holds 320 U.S. Gallons. The filter housing displays separate compartments for dirty and clean oil. Vomat‘s high capacity filter cartridges are long lasting, back washable and can be used with materials, such as Carbide, HSS, PKD and CBN. These filters require less maintenance and no filtration agents as some settling filters do.
Vomats full stream filtration systems warrant a 100% separation between dirty and clean oil. The system filter supply pump is frequency controlled, which allows for controlled and on demand filtration. The filters are automatically cleaned when needed. This saves energy and keeps the fluid at peak performance.
Vomat features as a standard an integrated compressor cooling system. It is possible to install the cooling unit also as a peripheral or resort to cooling via heat exchanger in case there is a plant wide cool water system available.
Apart from conventional sludge disposal via a sludge bag Vomat offers also a fully automatic disposal system, called the Sedimentator (patented). With this option the sludge is deposited in 55 Gallon drums, with less than five percent remaining fluid content ready to be picked up by your favorite recycler.
