Walter Introduces Capto Fine Boring Tool With Modualr Design
Walter has introduced the B3230 Walter Capto fine boring tool. This highly flexible, single edge precision boring tool, available in diameters ranging from 0.078 to 7.992 in. with an adjustment accuracy of 0.0001 in. on the diameter, can be used for standard as well as reverse machining and features internal coolant supply up to the cutting edge. A range of indexable inserts adapted for precision boring is available for use with this new fine boring tool, allowing for optimal cutting parameters to be employed for each material.
Heightening the B3230’s flexibility is the fact that it is available with the Walter Capto modular toolholding interface, as well as NCT and ScrewFit. Along with its high clamping force and even force distribution, the Walter Capto interface significantly enhances the new tool’s versatility. That’s because many of today’s machine tools include a Capto interface as standard because Capto is the most universal of interfaces, suitable for turning, drilling, counterboring and precision boring, as well as for milling, in both rotating and static modes. With this unique interface system, all machining operations can be performed on lathes, machining centers and turnmill centers.
Walter, a global leader in the metalworking industry with over 90 years of experience in precision cutting tools for milling, drilling, turning, boring and specialized tools, helps customers improve process reliability and increase productivity. With Regional Headquarters in Waukesha, WI, Walter markets its competence brands Walter Valenite, Walter Titex, Walter Prototyp and Walter Multiply through a strong network of distributors and field engineers across subsidiaries in the USA, Canada, Mexico, Brazil and Argentina.
