Walter WDN10 Diamond Inserts Offer Solution for High-Speed Machining of Non-Ferrous Materials
The WDN10 from Walter, a high-performance and extremely wear-resistant polycrystalline diamond (PCD) insert delivers outstanding hardness, a very low coefficient of friction, and minimum heat distortion. This helps result in maximum productivity and cost efficiency in the high-speed machining of non-ferrous materials. The WDN10 inserts achieve excellent surface finishes thanks to their exceptional cutting edge sharpness. This high degree of sharpness results from their PCD grain size and the manufacturing process. The WDN10 inserts boast chip breaker geometry, are laser marked with grade designation and ISO and ANSI corner radius designation and are backed by worldwide support from Walter PCD specialists.
