Metrology Education & Training Industry News
Zeiss Gear Pro: Learning to Measure Gears Simply and Efficiently
Zeiss has put out an invitation to a free webinar "Zeiss Gear Pro: Learning to Measure Gears Simply and Efficiently" on Thursday, November 2, 2023 from 11 a.m. to 12 p.m. (CDT). Measuring gears can present many challenges to metrologists, ranging from measuring mathematically defined curves, to calculating specialized characteristics such as profile error and dimension between pins, to displaying the results in a relevant way. Zeiss Gear Pro is software designed to make gear measurement simple and efficient. This webinar will cover how to use Gear Pro to define and measure gears, how to select the characteristics you wish to report, and how to integrate into an existing Calypso program to promote efficiency while running.
Highlights of the webinar:
  • Learn how to run a gear program in a CALYPSO measurement plan
  • Create gear geometry with only a few key pieces of information in a gear chart
  • Analyze and report results and export into ZEISS PiWeb software
REGISTER NOW
zeiss.com
