AGMA Releases Newly Affirmed Publications
The AGMA Technical Division is pleased to announce that ANSI has approved the reaffirmation of the following standards.
ANSI/AGMA 6033-C08, Materials for Marine Propulsion Gearing
Reaffirmed: February 7, 2020
Abstract: This document identifies commonly used alloy steels, heat treatments and inspection requirements for through hardened, case hardened and surface hardened gearing for main propulsion marine service over 1500 hp. Forged and hot rolled alloy steel bar stock are specified to two metallurgical quality grades (1 and 2) according to cleanliness and test requirements. Cast steel gearing is specified to a single metallurgical quality level. Mechanical, metallurgical and nondestructive test requirements are provided for various heat treat processes and metallurgical quality grades of gearing.
Pages: 34
ISBN: 978-1-55589-929-5
Pages: 34
ANSI/AGMA 6133-C08, Materials for Marine Propulsion Gearing (Metric Edition)
Abstract: This document identifies commonly used alloy steels, heat treatments and inspection requirements for through hardened, case hardened and surface hardened gearing for main propulsion marine service over 1100 kW.
Pages: 34
ISBN: 978-1-55589-930-1
Pages: 34
