Home » Repair via Isotropic Superfinishing of Aircraft Transmission Gears
May 1, 2009
The objective of this paper is to demonstrate that transmission gears
of rotary-wing aircraft, which are typically scrapped due to minor foreign
object damage (FOD) and grey staining, can be repaired and re-used with
signifi cant cost avoidance. The isotropic superfinishing (ISF) process is used to repair the gear by removing surface damage. It has been demonstrated
in this project that this surface damage can be removed while maintaining
OEM specifications on gear size, geometry and metallurgy. Further, scrap
CH-46 mix box spur pinions, repaired by the ISF process, were subjected to
gear tooth strength and durability testing, and their performance compared
with or exceeded that of new spur pinions procured from an approved
Navy vendor. This clearly demonstrates the feasibility of the repair and
re-use of precision transmission gears.
