Home » Evaluation of Methods for Calculating Effects of Tip Relief on Transmission Error, Noise and Stress in Loaded Spur Gears
January 1, 2012
The connection between transmission error, noise and vibration during operation has long been established.
Calculation methods have been developed to describe the influence so that it is possible to evaluate the relative effect
of applying a specific modification at the design stage. These calculations enable the designer to minimize the excitation from the gear pair engagement at a specific load. This paper explains the theory behind transmission error and the reasoning behind the method of applying the modifications through mapping surface profiles and determining load sharing.
