Home » Selection of a Proper Ball Size to Check an Involute Spur or Helical Cear Tooth
September 1, 1987
A much-used method for checking the tooth thickness of an involute gear tooth is to measure the dimension over two balls placed in most nearly opposite spaces in the case of external gears, and the dimension between the balls in the case of internal gears. This measurement is then checked against a pre-calculated dimension to denote an acceptable part.
