Daisuke Iba, J. Hongu, Hidetaka Hiramatsu, M. Nakamura, T. Iizuka, A. Masuda, I. Moriwaki and A. Sone
This paper proposes a new method — using neural oscillators — for filtering out background vibration noise in meshing plastic gear pairs in the detection of signs of gear failure. In this paper these unnecessary frequency components are eliminated with a feed-forward control system in which the neural oscillator’s synchronization property works. Each neural oscillator is designed to tune the natural frequency to a particular one of the components.
Introduction
The trend towards an increase in plastic gear usage has continued because it is cost-effective; low-density; capable of absorbing vibration; its ability to operate with no lubrication, and so on. If the limitation of plastic gears relative to metal gears were to be improved as a result of new developments in both materials and processing, plastic gears could be used under more severe conditions, such as high load and/or high rotation speed. But even before that, if, say, an emergency shutdown system could be provided to respond in a safe manner, applications for plastic gears would be more widespread. And yet, there are not many studies concerning a failure detection system for plastic gears compared with metal gears.
Iba et al (Ref. 1) carried out rotation fatigue tests of POM (polyoxymethylene) gears using their developed power-absorbtype gear test rig, and analyzed effects of gear tooth cracks at their root on measured acceleration responses. The acceleration responses were measured with a pick-up set at the top of a housing of the driven-side gear shaft bearing during the operation tests; frequency analyses were carried out to identify dominant frequency components in the tests. As a result of the frequency analyses the responses included not only the DC, shaft frequency, its harmonics, fundamental meshing frequency, some mesh harmonics and its modulating sidebands, but also rolling elements noise of bearings, motor vibration and its harmonics, and so on. The particularly conspicuous frequency components in the responses were the shaft rotation frequency; fundamental meshing frequency; and some meshing harmonics and its modulating sidebands — whose frequency is the same as the shaft frequency. The responses were strongly affected by amplitude and frequency modulations. These modulation phenomena may be due to the fact that plastic gears are so flexible in that their tooth stiffness is lower than that of metal gears, and are thus subject to greater dimensional instabilities due to their larger coefficient of thermal expansion. These modulating components complicate the procedure of analysis of the acceleration responses and hide plastic-gear-failure signs. In the frequency analyses of the response data, the peak of the meshing frequency results in a slight change in complete tooth fracture.
The response data include amplitude modulation; frequency modulation; rolling elements noise of bearings and motor; driving torque variation; and so on. Such complex data make detection of gear failure signs difficult, because the detection requires distinguishing slight changes in complex data.
On the other hand, non-linear oscillators — which were models for rhythm generators consisting of neurons — have been studied in biological study (Ref. 2) and are known as “neural oscillators.” Neural oscillators have a specific property to synchronize with periodic, external inputs in a certain frequency range. Mathematical models of the neural oscillators were also proposed and examined (Refs. 3–4), and their applications to walking robots were reported (Refs. 5–6). Iba and Hongu studied a new control system for active, mass dampers using the mathematical model of the neural oscillators that can track the vibration behavior of high-rise buildings due to this synchronization characteristic (Refs. 7–8). These studies provide the knowledge that the neural oscillator can be used as an adaptive notch filter that filters out the background noise of vibration and follows a variation of a designated frequency — autonomously.
In this study a new signal processing method has been developed using neural oscillators to filter out the background noise of vibration in meshing plastic gear pairs for detection of failure signs. As mentioned above, the acceleration responses — which are measured at the top of the bearing housing during operating tests — include multiple frequencies. If these unnecessary frequency components were eliminated from the responses, it would be easy to detect gear failure signs. But the normal notch filter cannot follow the change in the designated, unnecessary frequencies by driving torque variation, and the adaptive notch filter needs a periodic reference signal to follow the change. Therefore a new filter system (or feed-forward-type noise-cancelling system) — using neural oscillators that can autonomously follow the change due to their synchronization properties — is developed in this study. Each neural oscillator is designed to tune the natural frequency to a particular frequency of the components. This tuning process is called on for the removal. Moreover, the output phase of the oscillators is set at a difference of 180° from the input phase, and is combined with the original, measured response to eliminate unnecessary components. The ultimate goal is to detect the failure signs of gears from the output of the proposed filter system, but while development of the filter system is discussed in this paper, there is no direct mention of its failure detection method. The basic concept of the proposed system is introduced, after which the neural oscillator that constructs the proposed filter system and the configuration of the feed forward control system are explained. Next, a simulated acceleration response of a meshing gear pair is constructed and the proposed noise cancellation system is applied to the simulated response to confirm the validity of the proposed system.
Neural Oscillator
In this section the mathematical model of a neural oscillator is introduced, and the synchronization property of the oscillator — a key capability of nonlinear oscillators — is explained.
Mathematical model. Here Matsuoka’s neural oscillator is used as the neural oscillator (Refs. 3–4). The mathematical model of Matsuoka’s neural oscillator is expressed as follows:
Where, t is a time, and
This model contains two first-order lag elements to express excitation and inhibition, and can generate sustained oscillation. Generally, the five coefficients — s, τ, T, b, a — have been decided by identification of a biological neuron, but the specified animate being is not considered in this study. These parameters are chosen by our design method to generate the oscillation with a desired natural frequency (Ref. 8).
Further, in order to narrow the synchronization region to the rhythm generator, a mutual inhibition connection consisting of two neural oscillators is considered as follows:
Where, considering the connection weight w, the matrix to connect the two oscillators is obtained as follows:
Moreover, if XD = [XM,1 XM,2]tr, the equation, which expresses the dynamics of the neural oscillator, is given as follows:
Synchronization property. When the oscillator is subjected to an external periodic signal p (Ωt), the mathematical model of Matsuoka’s neural oscillator becomes:
Where, ED is an input matrix as follows:
Here, ε is an input gain, and p (Ωt) is a normalized sinusoidal signal whose frequency is Ω. If the frequency Ω is partially close to the Eigen frequency ωD of the neural oscillator, the oscillator is thus synchronized with the external sinusoidal wave.
This synchronization phenomenon can be seen when the detuning Ω-ωD between the oscillator’s frequency ωD and the external periodic force’s frequency Ω is a finite value. According to an analysis by the phase reduction method (Refs. 9–10), the synchronization region ε Γmin < Ω-ωD < ε Γmax is decided. Here, Γmin, max is the phase coupling function of the oscillator.
Figure 1 shows a synchronization region of the neural oscillator (Table 1).
While the neural oscillator has a sensitive reaction to the sinusoidal input within the synchronization region, it does not have the same sensitivity to the input outside of the region. Thus the neural oscillator can be used as an adaptive, single-frequency generator, and as an adaptive notch filter to cancel the unnecessary frequency component in the vibration response of the meshing gears.
Gear Meshing
In this section a model of gear meshing vibration in a circumferential direction — used for verification of a proposed noise-can-cellation system by simulation — is explained. Later, amplitude and frequency modulation caused by the eccentricities of gears are considered.
Dynamic loads on gear teeth. A simple vibration model in meshing gear pairs is used for simulation (Fig. 2).
Where, xth, meshing (t) is spring deflection of the vibration system; ωg is the natural frequency of the system; ζg is the damping ratio depending on the gear material; e(t) is tooth profile error — and this error is the input displacement to the system. Here it was assumed that the driving torque variation of the rotating shaft was small and the effect of the shaft stiffness on the line of action of force was small as well.
A meshing condition of a spur gear pair varies with time t. Considering the meshing period Tz, periodic change of total tooth stiffness during 0 ≤ t < z2Tz is expressed as follows:
In this study, the tooth profile error e(t) is also expressed as follows:
Where, εth is contact ratio of the spur gear pair, and is obtained as follows:
ωg,j is the time-varying, natural frequency of the meshing gear system during meshing period that is derived from Ishikawa’s tooth stiffness variation and the equivalent inertia mass on the pitch circle (Ref. 12). In addition, subscript j indicates the number of meshing tooth pairs, obtained as follows:
By using contact ratio εth,the transition time T2-1 from two pair teeth in mesh to a single pair is obtained as follows:
And Tsmooth is a time constant of a first-order lag system to vary the natural frequency smoothly, here as Tsmooth = σsmoothTz.
Xth,meshing changes periodically, the timeframe dependent upon the rotation of the driven gear as follows:
Amplitude and frequency modulation by an eccentric error of a driven gear. Generally the vibration caused by the tooth-totooth meshing of a rotating gear pair contains various frequency components that are due not only to amplitude and frequency modulation caused by eccentricity of gears, but also to the rolling- elements noise of bearings, motor vibration and its harmonics, and so on. The effects of these unnecessary components on the measured vibration make detection of gear faults — such as gear tooth cracks — difficult.
In this subsection a model that includes the amplitude and frequency modulation caused by an eccentric error of a driven gear is considered. Considering the meshing frequency ωz = 2π/Tz, the periodic variable is expressed as follows:
The effect of amplitude and frequency modulation on the variable can be expressed as follows (Ref. 13):
Where,
and e2 is the ratio of the radius of pitch circle of the driven gear to the eccentric error of the gear; ka is the amplitude modulation factor; mf is the frequency modulation factor; α is the pressure angle; and z the tooth number.
Numerical simulation of meshing gear vibration. According to the abovementioned gear model, numerical simulations of meshing gears are carried out using the Runge-Kutta Fourth Order Method (Table 2). The step time of the simulations is 10-6 s, and σsmooth = 10-2.
The results of numerical simulations are shown in following figures. Figure 3 shows the change of the natural frequency of the system.
Noise-Canceling System
Here a noise cancellation system using neural oscillators to filter out the background noise of vibration in meshing plastic gear pairs for detection of failure signs of the gears is explained. The acceleration response, which is measured on the top of the housing at the gear shaft bearing, includes not only the DC; shaft frequency; its harmonics; fundamental meshing frequency; some mesh harmonics; and its modulating sidebands; but also rolling-elements noise of bearings, motor vibration and its harmonics, and so on. Detecting gear faults is much more difficult in the complex response; therefore these unnecessary frequency components should be eliminated from the response. However, the frequency of the unnecessary components attracts a great amount of influence from the driving torque variation. The proposed new filter system using the neural oscillators can autonomously follow the frequency change of the unnecessary component due to the synchronization property (Fig. 8).
The proposed system has a measured signal and consists of some neural oscillators. The number of oscillators is the same as the number of unnecessary components. Each neural oscillator is designed to tune the natural frequency in to a particular frequency of the component. Moreover, the output of the oscillators is set to be out-of-phase with the input by 180° and is combined with the original, measured response to reduce the amplitude of the unnecessary components. The system is expressed as follows:
where βDk is an arbitrary output gain of the oscillator, and Lk is a delay time of the system. Moreover, the output of the each oscillator is obtained as follows:
Results of Numerical Simulation
to the simulated response to confirm validity of the system. In this simulation the analyzed signal consists of the abovementioned acceleration response and an unnecessary component 20sin (2π *7,250*t), which is the same frequency of the modulated, third-order, high-frequency content.
Figure 9 shows the abovementioned acceleration response without the noise, and Figure 10 the signal with the noise; in both figures the time is multiplied by 2π *7,250.
As can be seen, the modulated noise complicates the acceleration response of gear meshing, even if the noise consists of the single component.
Next are shown the results of the noise cancellation system. The frequency of the neural oscillator was set to the frequency of the unnecessary component (Table 1). Figure 11 shows the output of the designed neural oscillator and the noise component; as can be seen, the output of the neural oscillator has the same frequency of the noise, and is out-of-phase by 180°.
Figure 12 shows the result of noise cancellation using the original output of the neural oscillator. In this simulation, ε =0.0002 βD = 20/7, L = 5.5s. In the figure the unnecessary component was reduced by the effect of the proposed filter, but discontinuous changes can be seen due to the non-linear property of the neural oscillator. This non-linear oscillator — having a sinusoidal input — has a limit cycle. If “phase” is pre-defined on the limit cycle, the phase and amplitude of the neural oscillator as a sinusoidal wave can be constructed by the defined “phase.” To realize this construction, a phase map was used (Ref. 14). Figure 13 shows the result of noise cancellation using the constructed sinusoidal wave by the neural oscillator and the phase map. As can be seen, the original vibration of gear meshing is reconstructed.
Conclusions
This paper proposed a new method using neural oscillators to filter out the background noise of vibration in meshing plastic gear pairs for detection of gear failure signs. It was shown how to eliminate unnecessary frequency components, with a feedforward control system providing a neural oscillator’s synchronization property. Each neural oscillator is designed to tune the natural frequency to a particular frequency of unnecessary components. The designed neural oscillators can follow the change in the driving torque variation autonomously, using their synchronization property. Moreover, the output of the oscillators is set to have a difference in the phase of 180 degrees from the input, and is included in the original measured response to reduce the amplitude of unnecessary components. The proposed noise cancellation method applied to the simulated response, and it was concluded that the proposed system could sufficiently eliminate unnecessary vibration content. In future works we will design the suitable input and output gain for these oscillators, which could be determined through trial and error, and will confirm the oscillators’ tracking properties. Furthermore, we will validate the multiple-elimination of unnecessary components and will apply the advanced system to the acceleration response measured by operating tests of gears, and assessing the efficacy of the system.
Acknowledgements. The authors gratefully acknowledge the support of the department of mechanical and system engineering at the Kyoto Institute of Technology and Mitutoyo Association for Science and Technology, R1301.
References:
