New technology in CMM probes allow for touch probes to measure gears with high accuracy and repeatability.
On the surface, it may not seem like the gear inspection industry has changed much over the last few years. Shops still primarily use either machines that are dedicated solely to measuring gears, or multiuse Coordinate Measuring Machines (CMMs). And regardless of which machine they use, software serves as the backbone that supports their many diverse sensors.
Despite the turbulent economy of the last few years, the gear manufacturing market is expected to grow at a fairly modest CAGR of 5.73 percent through 2026, according to Technavio. As the industry expands, more gear manufacturers are streamlining and automating the inspection process with multisensor CMMs.
But underneath the surface, several exciting and innovative developments are driving the gear inspection industry forward. These bright spots have the potential to transform not only how gear inspection is conducted, but also the tools and processes that companies use as well.
While not new, CMMs continue to be a game changer in the industry. Combining multiple gear inspection and measurement tools into a single platform is a highly attractive feature for businesses, and provides several time- and cost-saving benefits:
Special CMM software supports measuring different types of worm gears using a touch trigger probe or scanning probe on a CMM.
One of the most exciting developments is the increasing harmonization of gear measurement standards across the globe. In the U.S., gear quality standards are set by the American Gear Manufacturers Association (AGMA). However, other countries utilize their own set of standards. For example, Germany relies on the German Institute of Standardization (DIN), while Japan utilizes the Japanese Industrial Standards (JIS), and several other countries have their own standards as well.
Many of these standards are similar, but not quite the same, which can be confusing and frustrating for companies that manufacture or sell gears in multiple countries. If a gear manufacturer is based in the U.S., but also has a facility in Europe, which set of standards should they use? This presents a similar challenge when using gear measuring software. Most software platforms have the major standards built in as selectable options, but knowing which one to use can be challenging.
To solve these challenges, the International Organization for Standardization (ISO) has been pushing for harmonization across the industry, and in recent years has made significant headway. Coordinating among the various standardization bodies—and getting them to agree on common standards—is a complex process. And when you factor in that gear measurement standards can encompass a multitude of different items, it’s easy to see why this could take so many years to complete.
While it may still be several years before we’re closer to full harmonization, this is an exciting development, both for manufacturers and companies that design measuring equipment and software. For manufacturers, recertifying a single gear or part under multiple standards can be a time-consuming and expensive process—harmonization can minimize effort and cost. For businesses that make measuring equipment or software, this would streamline the process of keeping up with new or updated standards.
Several innovations on the equipment side also offer exciting glimpses into the future of the gear measurement industry:
Noncontact laser probes have some advantages to measuring gears and parts of gears, including having great accuracy even though the measurements might take a little longer.
Standards harmonization and other technological advancements all offer intriguing new possibilities and point to a bright future. But it’s still critical to make sure you have the right inspection equipment and software, which will largely depend on the size, weight, and quality specifications of the gears you produce. Will your gears be under heavy load or subject to intense stresses? Is noise an issue? What kind of materials are they made of?
Answering these questions will help ensure that you have the measuring equipment and software that’s best suited for your needs. And having the right tools in place will help ensure that you can respond to the ever-evolving industry.
