This paper deals with analysis of the load sharing percentage between teeth in mesh for different load conditions
throughout the profile for both sun and planet gears of normal and HCR gearing—using finite element analysis.
(FEA).
This paper will demonstrate that, unlike commonly used low-contact-ratio spur gears, high-contact-ratio spur gears can provide higher power-to-weight ratio, and can also achieve smoother running with lower transmission error (TE) variations.
