Carburized gears have higher strengths and longer lives compared with induction-hardened or quench-tempered gears. But in big module gears, carburizing heat-treatment becomes time-consuming and expensive and sometimes cannot achieve good hardness due to the big mass-effect. Also, it is not easy to reduce distortion of gears during heat treatment.
The word gear, in various forms, has been in use since around A.D. 1200, according to the Oxford English Dictionary. Last issue we brought you Shakespearean gears. Now we'd like to show you some of the uses Americans have given our favorite word (from the Random House Dictionary of American Slang).
