Zimmerman Presents New Milling Machine with Linear Drive April 14, 2006 The new FZ 38 from Zimmerman is a CNC portal milling machine driven by linear motors. According to the company's press release, the ...Read More
PCB Piezotronics New Rotary Torque Sensor System April 12, 2006 The rotary torque sensor system from the Force/Torque Division of PCB Piezotronics is designed for automotive driveline and powertrain dy...Read More
Zero Maxs New Linear Actuators Convert Rotary Motion into Precise Linear Motion April 12, 2006 The Rohlix linear actuators from Zero-Max convert rotary motion to linear travel and carry loads at speeds up to 70" per second, de...Read More
Weilers New Brochure Details In-Machine CNC Deburring on Flat Surfaces April 11, 2006 Weiler Corp.s newest brochure details its in-machine CNC deburring of flat surfaces and highlights the companys Nylox disc br...Read More
Nortons New Gear Grinding Wheels Increase Life of Parallel Axis Spur Gears April 11, 2006 The new BRGg VPHS high speed grinding wheels from Saint Gobain are designed to reduce cycle times by increasing metal removal rates. The ...Read More
Ondrives New Gearbox Emphasizes Torque and Speed April 11, 2006 A new line of DC motorized worm and wheel reduction gearboxes from Ondrives is fitted with 24V DC motors that operate at 12V DC. Accor...Read More
Alpha Gears Gearmotor Offers Significant Reduction in Inertia April 11, 2006 The TPM from alpha gear drives Inc. is a geared motor containing a rotary actuator based on an AC servo motor and high precision planetar...Read More
Bourn & Koch Expands April 11, 2006 Bourn & Koch completed the addition of a new 20,000 square foot warehouse and a new 20,000 square foot two story engineering office build...Read More
United Grinding?s Newest Machine Grinds Shafts and Chucked Workpieces April 11, 2006 [photo] The Studen S242 from United Grinding is designed for the hard turning and grinding of high-precision applications for both shaf...Read More
Gleason Genesis S130SV Gear Shaving Machine April 8, 2006 The 130SV shaving machine from Gleason is the newest of the companys Genesis family of gear production equipment. Introduced to...Read More
