Bringing new or improved products to
market sooner has long been proven profitable for companies. One way to help shorten the time-to-market is to accelerate validation testing. That is, shorten the test time required to validate a new or improved product.
India is rapidly turning into a global manufacturing hub, thanks to the country’s manufacturing and engineering
capabilities, vast pool of skilled expertise and its size. These qualities offer it a strategic advantage for the manufacturing segment. A large number of international companies in varied
segments have already set up a manufacturing base in India and others are following suit. It only makes sense to bring this industry segment together under one roof to discuss the current
trends and technology prevalent to the marketplace. IPTEX 2012 is scheduled from February 9–11, 2012 at the Bombay Exhibition Center in Mumbai, India.
Gear flank breakage can be observed on edge zone-hardened gears. It occurs, for example, on bevel gears for water turbines, on spur gears for wind energy converters and on single- and double-helical gears for other industrial
applications.
The October 2011 issue of Gear Technology featured the article “Low-Distortion Heat Treatment of Transmission Components,” which covered
the combination of low-pressure
carburizing and high pressure gas quenching in an automotive environment. Here, heat treating expert Dan Herring explains why oil quenching is an appropriate choice for many applications.
This article describes some of the most important tests for prototypes conducted at Winergy AG during the product development process. It will demonstrate that the measurement results on the test rig for load distribution are in accordance with the turbine measurements.
In this study, limiting values for the load-carrying-capacity of fine-module gears within the module range 0.3–1.0 mm were determined and evaluated by comprehensive, experimental investigations that employed technical, manufacturing and material influence parameters.
