AGMA introduced ANSI/AGMA 2015–2–A06—
Accuracy Classification System: Radial System for Cylindrical Gears, in 2006 as the first major rewrite of the
double-flank accuracy standard in over 18 years. This document explains concerns related to the use of
ANSI/AGMA 2015–2–A06 as an accuracy classification system and recommends a revised system that can be of more service to the gearing industry.
How well you conduct your inspections can be the difference-maker for securing high-value contracts from your
customers. And as with most other segments of the gear industry,
inspection continues striving to attain “exact science” status. With that thought in mind, following is a look at the state of gear inspection and what rigorous inspection practices deliver—quality.
years ago.
