Robert Errichello
Design Optimization Manufacturing Processes Grinding Hobbing Workholding Mandrels Inspection Testing Vibration Lubrication Tribology Technical Ground Gears
The Lubrication of Gears - Part II
What follows is Part 2 of a three-part article covering the principles of gear lubrication. Part 2 gives an equation for calculating the lubricant film thickness, which determines whether the gears operate in the boundary, elastohydrodynamic, or full-film lubrication regime. An equation for Blok's flash temperature, which is used for predicting the risk of scuffing, is also given.
This article appeared in the May/June 1991 issue.
