Design Optimization Ratio Manufacturing Machine Tools CNC Controls Processes Casting Grinding Inspection Metrology Lubrication Coatings Materials Alloys The Gear Industry Trade Shows & Events IMTS Sectors Aerospace Automotive Mining Emerging Technologies Additive Manufacturing Automation Robotics IIoT Industry 4.0 Technical Planetary Gears
Efficient Methods for the Synthesis of Compound Planetary Differential Gear Trains for Multiple Speed Ratio Generation
This article presents an efficient and direct method for the synthesis of compound planetary differential gear trains for the generation of specified multiple speed ratios. It is a train-value method that utilizes the train values of the integrated train components of the systems to form design equations which are solved for the tooth numbers of the gears, the number of mating gear sets and the number of external contacts in the system. Application examples, including vehicle differential transmission units, rear-end differentials with unit and fractional speed ratios, multi-input functions generators and robot wrist joints are given.
This article appeared in the July/August 1990 issue.
