Napoleon Engineering Services Announces Rolling-Contact Fatigue and Wear Testing
The largest independent bearing testing and inspection facility in the United States, Napoleon Engineering Services (NES) has announced their advancements in proven test technology offering expanded test opportunities for low-cost, proof-of-concept research.
Ball-on-Rod RCF Tester
The NES Three-Ball-on-Rod Tester represents one of the most economical rolling contact fatigue proof of concept tests available in the industry. Testing is performed to evaluate the influence of heat treatment, material, lubricant, and coatings on fatigue life.
The advantage of the NES tester is that run times are short and a single rod specimen can provide many failure data points thereby containing overall project costs. High stress cycle accumulation per revolution and stress levels up to 900 ksi (6.2 GPa) provide many options to the test engineer. NES has designed these RCF testers with oil heaters, lubricant flow control, test fixture temperature monitoring and vibration sensors with a dedicated data acquisition and monitoring system to ensure test integrity.
Five-Ball Tester
The NES Five-Ball tester captures many of the intricate mechanics of bearing fatigue making it very attractive for simulation of full scale bearing testing of ball bearings without full scale costs.
