Inspection Wear Technical
Calculation of Slow Speed Wear of Lubricated Gears
On gear drives running with pitch line velocities below 0.5 m/s so called slow speed wear is often observed. To solve some problems, extensive laboratory test work was started 10 years ago. A total of circ. 300,000 h running time on FZG back-to-back test rigs have been run in this speed range.
This article appeared in the November/December 1985 issue.
