Design Stress Manufacturing Processes Honing Inspection Roughness Surface Finish Surface Roughness Technical
Basic Honing & Advanced Free-Form Honing
Rotary gear honing is a crossed-axis, fine, hard finishing process that uses pressure and abrasive honing tools to remove material along the tooth flanks in order to improve the surface finish (.1-.3 um or 4-12u"Ra), to remove nicks and burrs and to change or correct the tooth geometry. Ultimately, the end results are quieter, stronger and longer lasting gears.
This article appeared in the July/August 1997 issue.
