Design Contact Analysis Inspection Transmission Error Technical
Hybrid Hertzian and FE-Based Helical Gear-Loaded Tooth Contact Analysis and Comparison with FE
Gear-loaded tooth contact analysis is an important tool for the design and analysis of gear performance within transmission and driveline systems. Methods for the calculation of tooth contact conditions have been discussed in the literature for many years. It's possible the method you've been using is underestimating transmission error in helical gears. Here's why.
This article appeared in the July 2016 issue.
