Design Backlash Profile Profile Shift Tooth Thickness Manufacturing Workholding Chucks Inspection Measurement The Gear Industry AGMA Ask the Expert
Tooth Thickness Tolerance and AGMA 2002-C16
A reader asks: We are currently revising our gear standards and tolerances and a few questions with the new standard AGMA 2002-C16 have risen. Firstly, the way to calculate the tooth thickness tolerance seems to need a "manufacturing profile shift coefficient" that isn't specified in the standard; neither is another standard referred to for this coefficient. This tolerance on tooth thickness is needed later to calculate the span width as well as the pin diameter. Furthermore, there seems to be no tolerancing on the major and minor diameters of a gear.
This article appeared in the July 2019 issue.
