Manufacturing Processes Bevel Gear Grinding Grinding Inspection Transmission Error Technical Bevel Gears
Influence of Topography Deviations on the Psychoacoustic Evaluation of Ground Bevel Gears
In the design process of transmissions, one major criterion is the resulting noise emission of the powertrain due to gear excitation. Within the past years, much investigation has shown that the noise emission can be attributed to quasi-static transmission error. Therefore, the transmission error can be used for a tooth contact analysis in the design process, as well as a characteristic value for quality assurance by experimental inspections.
This article appeared in the November/December 2016 issue.
