Inspection Measurement Roughness Surface Roughness Technical
Improving Gear Manufacturing Quality With Surface Texture Measurement
The working surfaces of gear teeth are often the result of several machining operations. The surface texture imparted by the manufacturing process affects many of the gear's functional characteristics. To ensure proper operation of the final assembly, a gear's surface texture characteristics, such as waviness and roughness, can be evaluated with modern metrology instruments.
This article appeared in the March/April 1993 issue.
