Design Temperature Manufacturing Cutting Tools Abrasives CBN Processes Form Grinding Grinding Inspection Vibration Heat Treating Furnaces Technical Worm Gears
CNC Controlled CBN Form Grinding
Borazon is a superabrasive material originally developed by General Electric in 1969. It is a high performance material for machining of high alloy ferrous and super alloy materials. Borazon CBN - Cubic Born Nitride - is manufactured with a high temperature, high pressure process similar to that utilized with man-made diamond. Borazon is, next to diamond, the hardest abrasive known; it is more than twice as hard as aluminum oxide. It has an extremely high thermal strength compared to diamond. It is also much less chemically reactive with iron, cobalt or nickel alloys.
This article appeared in the May/June 1984 issue.
