Manufacturing Processes Grinding Inspection Grinding Burn Materials Crack Propagation The Gear Industry Sectors Aerospace Technical
Gear Failure Analysis Involving Grinding Burn
When gears are case-hardened, it is known that some growth and redistribution of stresses that result in geometric distortion will occur. Aerospace gears require post case-hardening grinding of the gear teeth to achieve necessary accuracy. Tempering of the case-hardened surface, commonly known as grinding burn, occurs in the manufacturing process when control of the heat generation at the surface is lost.
This article appeared in the January/February 2009 issue.
