Steve Lovell
Inspection Metrology The Gear Industry AGMA Technical Big Gears
Girth Gears - More than Just Metal and Teeth
Large, multi-segmented girth gears do not behave like the relatively compact, rigid, monolithic structures we typically envision when discussing gear manufacturing. Girth gears are very large, non-rigid structures that require special care during the machining of individual mating segments as well as the assembled gear blank itself.
This article appeared in the May 2017 issue.
