Manufacturing Processes Honing Isotropic Superfinishing Superfinishing Inspection Surface Finish Materials Micropitting Pitting Technical
Case Study Involving Surface Durability and Improved Surface Finish
Gear tooth wear and micropitting are very difficult phenomena to predict analytically. The failure mode of micropitting is closely correlated to the lambda ratio. Micropitting can be the limiting design parameter for long-term durability. Also, the failure mode of micropitting can progress to wear or macropitting, and then go on to manifest more severe failure modes, such as bending. The results of a gearbox test and manufacturing process development program will be presented to evaluate super-finishing and its impact on micropitting.
This article appeared in the August 2012 issue.
