A Lesson in Workholding Fundamentals
Evolution of a Real-World Workholding Solution
Initial Design
The Demo Part is a 6 DP involute spur gear with 46 teeth, 40 mm wide, and made of 8620 steel. The pitch of this part is near the maximum rating of the machine, 4.23 DP. The part was cut by a 3.5” outside diameter high-speed steel hob with one thread, fourteen straight flutes, and AlCrN coating.
We initially planned to use existing fixturing pieces to save on time and costs by fitting the gear blank onto a modular precision fixturing system that provided the concentricity and perpendicularity needed to produce a high-quality gear. In this design, the blank is held between two pieces: a long arbor piece with a 32 mm diameter shaft for collet clamping at one end with an 80 mm diameter boss to hold the part, and a centering piece with a mirrored boss and clamping face, clamped by an M12 bolt through the bore. The pilot diameter of the arbor piece is held to a tight (h4) size tolerance and 3-micron runout to the 32 mm shaft that is clamped by the 16C collet on the machine’s work spindle. The clamping faces of the arbor and center piece are also held to a 3-micron runout tolerance to keep the blank parallel to the work spindle. The assembly is shown in the machine pictured above.
Performance of Initial Design
When fully assembled, this fixturing setup measured over 340 mm in length, including the arbor piece, the gear blank, and the centering piece. This total assembly is loaded into the collet chuck by hand and clamped by the center on the machine’s tailstock. The intention was that the M12 bolt holding the assembly together, paired with the hydraulic tailstock of the machine, would provide enough clamping force to hold the part during the cut.
This setup was successful in its ability to hold the part while hobbing. However, this is not the only criterion of a successful cut. The fixturing assembly was very long relative to its width and only held to the work spindle by the collet. This combination created a great deal of vibrations during the cut that could be heard throughout the shop and felt in the floor around the machine. Even after a two-cut cycle, the finished part was not satisfactory: the surface finish was covered in chatter marks, and it is unlikely the gear would have passed an analytical inspection for even an AGMA Q6 part.
Second Design
The goal of the second design was to decrease the vibrations in the fixturing and increase the clamping pressure on the part. This new design carried over the basic principles of the original setup. There was one piece that bolted to the machine’s worktable and held the blank in a parallel and concentric position. The clamping force came from a second piece, also fitting into the bore of the blank, that was bolted to the first piece through the bore of the part. A section view of the fixturing assembly is shown in image 2. Image 2 does not show the hydraulic tailstock used during hobbing. The clamping faces of both pieces were designed so that only a 12.7 mm [0.5”] wide band would be contacting the blank. In the original design, the part’s entire face, from the bore to the outside clamping diameter, was in contact with the blank, about 31 mm. Assuming the same force clamps through the same size bolt, the decreased clamping area would provide increased pressure on the part.
Performance of Second Design
In this second design, the solid fixturing piece was clamped to the spindle face. The gear blank was loaded onto this piece with a close sliding fit between the pilot diameter and the bore of the blank. The second piece was loaded onto the blank and clamped by tightening the bolt through the center. This setup also utilized the clamping force of the tailstock of the machine.
