Design Fatigue Tooth Bending Inspection Testing Technical
Bending Fatigue Tests of Helicopter Case Carburized Gears: Influence on Material, Design and Manufacturing Parameters
A single tooth bending (STB) test procedure has been developed to optimally map gear design parameters. Also, a test program on case-carburized, aerospace standard gears has been conceived and performed in order to appreciate the influence of various technological parameters on fatigue resistance and to draw the curve shape up to the gigacycle region.
This article appeared in the November/December 2009 issue.
