Shorter Cycle Times for Carburizing
Dana Corp. is developing a process that carburized a straight bevel gear to a carbon content of 0.8% in 60 fewer minutes than atmosphere carburizing did with an identical straight bevel.
The Dana process, called AtmoPlas, uses plasma and microwaves to carburize workpieces at atmospheric pressure. Moreover, in the above test, the atmosphere carburized gear achieved a case depth of 0.035", the AtmoPlas processed gear: 0.045".
The test was one of many AtmoPlas trials being run by Dana with its lab research system to benchmark the carburizing of various single workpieces.
In trials, the microwave technology results in shorter cycle times than atmosphere carburizing, with time saved in the heat-up and carburizing parts of the cycle. "This would translate to overall lower gas consumption and lower power cost," says Kuruvilla Cherian, a Dana senior materials scientist and one of the developers of the AtmoPlas process.
In the above benchmark test, the straight bevels were differential side gears with outer diameters of 70 mm (about 2.76"). They were made of 8620 steel and had starting carbon contents of 0.2%. The AtmoPlas lab system was programmed to carburize its gear at 930 °C. The other identical gear was atmosphere carburized at the same temperature.
Cherian provides the results for both treatments. The total time for the atmosphere carburizing was 272 minutes, and for the AtmoPlas processing: 212 minutes. The atmosphere carburizing time consisted of 142 minutes for the boost phase, 110 for the diffusion and 20 for the temperature-drop. The AtmoPlas time was 112 minutes for the boost phase, 80 for the diffusion, and 20 for the temperature-drop. Afterward, both gears were oil quenched.
