With growing markets in aerospace and energy technologies, measuring hob cutters used in gear cutting is becoming an essential requirement for workpieces and machine tools. Zoller, a provider of solutions for tool pre-setters, measuring and inspection
machines and tool management software,
has developed a new partnership with Ingersoll/Germany for shop floor
checking of hob cutters by a combined
hardware and software approach.
At Andrew Tool, CMMs have been an integral part of their manufacturing processes for years, but they had never faced a project with such intricate measurements, tight tolerances, heat treatments and a very short time frame requirement.
In comparison with the traditional gear design approach based on preselected, typically standard generating rack
parameters, the Direct Gear Design method provides certain advantages for custom high-performance gear drives that
include: increased load capacity, efficiency and lifetime; reduced size, weight, noise, vibrations, cost, etc. However, manufacturing such directly designed gears requires not only custom tooling, but also customization of the gear measurement methodology. This paper presents definitions of main inspection dimensions and parameters for directly designed spur and helical,
external and internal gears with symmetric and asymmetric teeth.
A study was performed to evaluate fault detection effectiveness as applied to gear-tooth pitting-fatigue damage. Vibration and oil-debris monitoring (ODM) data were gathered from 24 sets
of spur pinion and face gears run
during a previous endurance evaluation
study.
The great thing about a trade show the size of IMTS is the amount of options available to attendees. If you’re into cars, fighter jets, machine tools,
fighting robots, manufacturing relics or
simply the latest technology advancements in a particular industry, you’ll find it at IMTS 2010.
Minimizing gear losses caused by churning, windage and mesh friction is important if plant operating costs and
environmental impact are to be minimized. This paper concentrates on mesh friction losses and associated scuffing risk. It describes the preliminary results from using a validated, 3-D Finite Element Analysis (FEA) and Tooth Contact Analysis (TCA) program to optimize cylindrical gears for low friction losses without compromising transmission error (TE), noise and power density. Some case studies and generic procedures for minimizing losses are presented. Future
development and further validation work is discussed.
